Hi
I'm thinking of getting an N95 soon (have had an N73 for a year or so) the upgrade would only really be for the TV-Out capability. I'm wanting to use the phone with a 10" portable TV/DVD player but its AV-IN input is a jack-type socket. I've got a jack to jack cable that works with my camera but wondered what the socket on the phone for the TV-Out is (yes, I should go and look at one in a shop! but hoping you guys will help me out) - will it be a problem to find a suitable cable as I believe the cable that comes with the N95 has the more usual phonos?
thanks
-H
The cable is depicted here:
http://europe.nokia.com/link?cid=EDITORIAL_183273
The phone side connector is a 3.5mm connector that handles just headphones or the TV/AV cable.
Thanks very much for your help. :icon14: It looks as though the cable I have for my camera will suit.
-H
When you buy the N95 (or N95 8GB), the sales package will come with the Nokia cable.
N/A wrote:When you buy the N95 (or N95 8GB), the sales package will come with the Nokia cable.
That one won't fit my TV though, I only have a jack-type input on it, not scart or phono.
-H
aitchsee wrote:That one won't fit my TV though, I only have a jack-type input on it, not scart or phono. -H
the n95 tv-out cable is RCA connection red, yellow and white. stereo sound and video (yellow). its standard connections, so as long as your player cable has jack to RCA converter, it will work fine i assume.
