w960 unwanted install query
1 replies · 5,869 views · Started 02 August 2008
Hey everyone 😊 So here's the problem... When I start my phone (or when disconnect the usb cable from it) several messages about installing applications (which I removed recently) pop up and ask me if I want to ... even though the installation files are deleted. I tryed master reseting the phone, but it doesn't seem to solve the problem, also I tryed to upgrade the firmware... and the result is the same.
Does anyone have an idea what can I do.. to solve this ?
Hey Reveille - I have the same issue. Whenever you save a SIS file for install, it seems to additionally save install info somewhere inaccessible. My issue was after I reset the phone, but the memory card still had the install files. Only way I found to solve was to
a) run the installation of the SIS in querstion
b) then uninstall using the SE uninstall
Bit painful but that was all I could do.
S
