E71- Sync advice
4 replies · 4,428 views · Started 02 August 2008
I posted a few weeks ago regarding the issues I had with Mail for Exchange and the fact that it wasn't sycing with my company's outlook exchange server (used to get 'account requires secure connection errors'.
Since then I got my hands on a blackberry and used blackberry internet service and was successfully able to get my email synced via the 'outlook web access option' in BIS.
I was just wondering if M4E , roadsync or any other sofware for the E71 supports outlook web access sync (where you have to put the outlook web access exchange address rather than the normal server address)?
Cheers!
A.J. wrote:There is free app from Nokia: Mail for Exchange. It works nice.
I was wondering about this myself. I bought RoadSync when I had my E61i because of its ability to sync subfolders, but would gladly use Mail for Exchange if they've finally gotten this feature implemented.
Does anyone know if this feature is present in the current incarnation of Mail for Exchange?
jorang wrote:You may also like to try SEVEN - http://www.seven.com/
It comes i different versions - try it out before you buy a client for your device 😉
I was one of the original private beta testers on this app a while back. As I remember, their HTML implementation was lacking; I can't imagine that's changed much, has it?
