Hi, my standard N95 plum is beginning to look very scratched and tired, so looking for a full replacement.
I have seen these BLACK ones on eBay, that claim to be genuine, and do look it, but im still not sure....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=260267686149&ssPageName=STRK:MEWA:IT&ih=016
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=270261618148&ssPageName=STRK:MEWA:IT&ih=017
what does everyone think about these?? Has an N95 been released in black?? Anyone had any experience with these or some pictures??
Failing that im gonna order a new genuine housing - does this one look good??
http://cgi.ebay.co.uk/Genuine-Nokia-N95-Original-Plum-Housing-Brand-New_W0QQitemZ110275497157QQcmdZViewItem?hash=item110275497157&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Cheers for any help guys!
I bought it from a seller in Hong Kong on eBay for appx. $20.
The black housing looks pretty cool and the quality seems to be very good. The back feels like rubber/leather like the original and the front is metal. All Nokia/N95 prints are like the original.
All seems to fit just as well as the original housing. I chose not to replace the lower part of the slider (it requires a bit too much messing around with the insides of the phone. And also I chose to leave the bottom part (usb, power) since it holds the GPS receiver and cannot easily be moved to the new black housing.
Although it leaves a few blank parts it still looks well cool with the black cover surrounding it. And it is a fairly easy operation to change the housing (if you leave out the parts I mentioned above). You might want to take a look in the official repair manual first though.
You'll need both a T5 and T6 screwdriver (and preferably a Nokia disassembly plastic tool) to do the job.
let me give you guys a tip if you plan to change housing colour. NEVER change the lower base of the housing ( the plastic bit where charger and USB goes into)
This is also where the GPS antana is, once removed u will never get signal again.
good luck.
@nennyrules you may want to check out my blog post on a succesful switch from plum to black: http://blog.uhuru.de/2008/02/25/black-is-beautiful/
Changing the complete (!) cover requires the removal of a small magnet below the display that triggers the sensor (opened/closed slider) and also the mentioned GPS antenna which is glued to the lower plastic cover. I managed to carefully remove it though and stick it into the new one.
Next time I'd just buy a cheap cover and paint the rest in black colour. Black keypad isnt also that great - quickly wears off etc.
hth!
jke
