Have 3650 + 16mb still cant run Doom?
3 replies · 2,659 views · Started 09 February 2003
Hi guys.
Have a 3659 with 16mb card.
If I install dom to the phone it will not run saying no memory.
So I installed it to the MMC card with 14mb free but then the game does not run at all saying files are missing - I guess it's looking on the phone for it's files rather than the mmc card where it's installed.
Any ideas how to get it working from the mmc card??
Cheers 😊
:robot:
I think when the 3650 is officially released thety will make an other version of Doom what will work at 3650
upload it on your mmc then search it with seleq or some other file manmager and click on open
that should do the trick
if it doesn't tell me and I'll try it on my phone
note that as with most systems there is free storage and free system memory. press and hold the menu button to show all running apps. You may find you have more in system memory than think!
Also had goboy crap out to a text prompt, hope it happens a gain so I can get a picture 😊
