Im wondering if you can tell if your battery is burning out by looking at the voltage after charging your phone. What is it for most people on here after a full charge checking with energy profiles on firmware v21.
Does anyone know if their is any best way to check?
Don't know about energy profiles but the voltage on my N95-1 (4months old) is 4.14v immediately after a full charge.
Mine is about 4.11-4.13 after full charge.
mine is around 4.13V at full charge. i assume that over time, as the battery degrades, this voltage will gradually get lower as the batter wears out.
RogerPodacter wrote:mine is around 4.13V at full charge. i assume that over time, as the battery degrades, this voltage will gradually get lower as the batter wears out.
Not really sure i would guess the same, but its hard to know without some kind of hardware expert.
RogerPodacter wrote: i assume that over time, as the battery degrades, this voltage will gradually get lower as the batter wears out.
Actually, modern rechargeable battery life is more like walking towards a cliff-edge.
One day the battery is OK, then suddenly it either dies completely or time required between full charge and empty reduces drastically.
