Bluetooth Internet Connection Over Lan
3 replies · 3,096 views · Started 09 February 2003
Hi im trying to get my 7650 to connect to the internet using my pc internet connection. I have the bluetooth all setup and working. I just have no idea how to set it up on the 7650. I don't have gprs if that helps/
Hi. If you try the search (it's on the top of this page) you will find EXACTLY what to do about your problem. Thanks 😊
already done that, no need to be sarcastic!
But none of the previous posts explain the pc settings?
I didn't want to be sarcastic. I searched, and I found this http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=4408&highlight=gprs+bluetooth. I suppose it's what you are looking for.
