wLan Wiz.
2 replies · 23,039 views · Started 05 August 2008
I have a problem with the wLan wiz. When I try to open the app. I get a message "System Error" en nothing will happen.
On my standby-screen there is a empty-row where until yesterday the wLan wiz. was.
Any idea how to slove this?
Regards,
Tim Hanssen
Have you turned off the phone and removed the battery for about a minute and turned it back on?
If that doesn't work, I suggest a hard reset and if that doesn't work then you'll have to reinstall your software.
Always make a backup of your phone applications and contacts, messages etc before attempting any reset.
Timmetjenl wrote:I have a problem with the wLan wiz. When I try to open the app. I get a message "System Error" en nothing will happen.
Regards,
Tim Hanssen
i'm facing the same problem with my handset. if u have got the solution please help me.
