Hi can anyone help please,
On my nokia n95 when sat nav is runing al works great except to say that there are no voice comands to go along with directions on screen, i have just subscribed to nokia yesterday to enable sat nav to run.
i have checked the possible silly mistakes ie; volume is turned up and set on english ect.
thanks very much in advance for any help to solving this small problem,
ps; the software is all above board in phone.
cheers!!
jazzy 29.
no voice coms on n95 sat nav
jazzy29 wrote:Hi can anyone help please,
cheers!!
jazzy 29.
...did you download the voice pack using Map Loader software? (did you download the maps using the Map Loader or were they preloaded?)
Hi the maps were pre loaded into phone, it was my friends phone.
only thing is when i subscribed to nokia yesterday wouldnt the maps all been updated?
thanks.
.....may be worth downloading the Nokia Map Loader and putting the maps and voice pack on (again?) as a double check. The Map Loader is in step 4) of this link http://europe.nokia.com/A4984199.
As evilweasel says use the latest map loader. Also don't forget to wipe your existing maps first with map loader. If you click on (I think) 'Services' it will also show what you've subscribed to.
Thanks very much folks, downloaded maps again then was asked to install voice pack, job done, thanks very much to all.
jazzy29
