E71 and synching of bookmarks- how?
7 replies · 4,042 views · Started 06 August 2008
Okay, I got my E71 this morning, and I've finally got everything installed.
One thing, though: I was under the impression that with the latest version of PC Suite (7.0) and this device that you would be able to synch your desktop bookmarks to the device, like the N95.
I hope this is true, I don't relish spending hours typing every bookmark back into my device anytime soon!
If anyone knows how to do this, please let me know; I've searched all over but couldn't find anything on this.
Thanks!
I'm surprised not to hear from other E71 users on this. To me, at least, this is a major deal, and one of my pet peeves from the early days of my E61i.
Coming from a Windows Mobile world, where Mobile Favorites in IE7 are synched, I too would like to know how to do this!
Okay, I've figured out how to synchronize the bookmarks. I must say that they've certainly hidden it well enough!
It seems to work very much the same way as with Windows Mobile, it will create a folder in your desktop browser's bookmarks list called "mobile bookmarks" that it syncs to the device from.
I'll go through it step-by-step:
1- Right click on the PC Suite icon in the system tray in Windows, select synchronize.
2- Use the sync setup wizard (it'll be easier this way), select your desktop PIM application (for me, it's Microsoft Outlook). Don't worry, if you use Exchange like I do, you don't have to sync anything from Outlook, it will be explained in the next step or two.
3- On the next page there will be an option to sync contacts, calendar, tasks, bookmarks, etc. Uncheck all of them except for bookmarks.
4- Choose how you want the synchronization conflict resolution to go, I usually choose letting the desktop overwrite the device, unless you have bookmarks on your device you want to keep, then choose synchronize in both directions.
5- The next step will ask you if you want to synchronize automatically or manually, I always choose the manual sync.
6- Uncheck the box that says begin synchronization upon completion of this wizard. Complete the wizard and then go back to your desktop browser and arrange the bookmarks you want to synchronize. For me, I only wanted certain ones synchronized, so I copied and pasted them into the "Mobile Bookmarks" folder. Small note: folders within folders will not be synchronized, so plan accordingly. In Windows, you'll find the browser bookmarks folder in a file structure that looks like: C:\Documents and Settings\your username\Favorites or C:\Documents and Settings\Administrator\Favorites.
7- Synchronize and you're ready to go!
Note: There is a bug that has persisted for years in Nokia's browser bookmarks that still exists. No matter how you enter bookmarks or folders containing bookmarks, they will be in reverse from z to a. I've mentioned this to Nokia marketing and technical people over the years, but it has never been addressed. So if you do notice this, it's nothing you've done wrong, it's just that bug.
Enjoy!
Thanks for that - I could have sworn I tried that the first time, but "Bookmarks" ws not listed as an option for synching - just files/folders....
Anyway, it's all good now.
BTW, your bug seems to be valid for bookmark folders, but not individual bookmarks themelves. Bookmarks are sorted a - z and folders z - a on my E71. (except for the pre-installed nokia "Download" bookmark folders, which seem to be placed first in the list before my personal bookmark folders.
vbap wrote:Thanks for that - I could have sworn I tried that the first time, but "Bookmarks" ws not listed as an option for synching - just files/folders....
Yes, I noticed that too.
I did, however, discover how to override the reverse folder listing bug: If you highlight each folder and then select bookmark manager, move, you can put them in the proper order alphabetically. It's a chore if you have a lot of folders as I have, but it does work.
Cheers! :icon14:
