I am having problems installing 3rd party disctionary software on my e90 running firmware v07.40.1.2, 03-10-2007, RA-6, Nokia E90 (01). I keep ghetting a message �unable to install !� and the application terminates and autoexits.
Can anybody help? Is there some setting on the e90 that could be blocking the installation? The new girlfriend is french so I have very powerful incentive to get a dictionary working on the e90 !!
Below is one example that I have just done from the beginning and recorded on here step-by-step.
Thanks, Richard
I went to:
http://www.slovoed.com/French-English.html
I selected "mobile dictionary" and got a page to select manufacturer (Nokia_E-series) and then selected device (e90) to get:
http://www.slovoed.com/S60_3rd_Edition/SlovoEd/French-English.html
I selected �try� and downloaded a zip file:
Merriam-Webster's_EnglFren_FrenEngl_for_S60_3
I double clicked on the zip file in Windows explorer, drilled down to the program folder (attached) and found three files:
Merriam-Webster's_EnglFren_FrenEngl_for_S60_3 - this is version 2.03(0)
Morphology_module_for_S60_3
Merriam-Webster_v_3_0_for_S60_3 - this is version 3.00(3)
I hooked up my E90 to the PC (running Windows XP professional and selected �PC Suite� connection mode. I got a balloon telling me that my E90 was connected.
I double clicked �Morphology_module_for_S60_3� to run it and got a Nokia PC Suite dialogue box saying �Do you want to install the application to the phone?� I selected �yes�
Nokia Application Installer dialogue box appeared saying �Finish the installation on the phone user interface or cancel�
On the phone (inside screen) a dialogue box had appeared saying �Install Morphology Module�. Options were �yes� (selected) or �no�
Another dialogue box appeared
�Details
Name
Morphology module
Version
2.04(0)
Certificates
View details�
Options are �continue� or �cancel�
When continue selected, msg �unable to install !� appears and the application terminates and autoexits.
When I download the files on to the phone microSD card and try to install from there, exactly the same thing happens.
