I have a N95 8GB and I don't kno how but the flash light on the back at the camera lens has came on and I cant get it off!!! I have went through all phone settings and the book but I cant get it off, its like a torch but not a torch on phone! The flash etc are all switched off, the only way of getting it of is takin battery out, its draining my battery really quick :con?:frown:
Help!!!!!
Hi, I have had my N78 for 3 month and I just started having this problem too. 😞 It's running my battery down so fast!
I've seen in other forums where people suggested that you hard reset the phone with green button, *, and 3, and hold down power button to turn it on.
I've seen where people said it's because of water or moisture in the phone and some repair shops won't fix it, but some will. I think I'll take mine to the repair shop and see what they can do.
