I use both a Stowaway Bluetooth keyboard and a Jabra BT125 BT headset with my N95, and wondered if anyone else has encountered the problem I have with this setup:
Basically, if the Jabra is powered up and linked to the N95, the Stowaway won't connect unless I either (a) go to the "Stwy" application and re-pair the keyboard with the phone, or (b) turn off the Jabra, in which case the Stowaway connects straightaway.
Is this a known issue, and if so, does anyone happen to know a solution?
Many thanks,
Tim.
