PC Suite for XP
2 replies · 1,580 views · Started 10 February 2003
Here's a remarkably informative piece of news from Nokia "Careline" I thought I would perhaps share....
Thank you for contacting Club Nokia Careline.
With regards to your query about an XP-compatible version of the PC Suite,
this should be available at a future date. When this is available you will
be able to download it from http://www.nokia.com/cda1/0,1080,2015,00.html
ie from that uninformative place "Nokia.com"
I'd hold my breath only that would probably make me die....
hi,
what exactly is the problem PC Suite has with XP? I've been using it with XP Pro SP1 both via bluetooth as well as IR and have had no problems so far.
nirudha
HI!..
me too..
I am using XP Pro with Belkin BT USB Adapter and i have no problems at all... all work perfect...
Just one trick to get connected with PC SUITE .. like double click the NOKIA SERIAL PORT Icon on My BT Places , then after it said.. I CAN'T MAKE THE SERIAL CONNECTION"... then the sys tray icon blink and get connected... check if you are on the right port.. but testing you will get it...
cya!
PD: i give many details of this operation to another topic in this forum right now... titled NEWBIE Question... check that out
