E51 & Installing tom tom
1 replies · 12,643 views · Started 10 August 2008
Hi all, I recently bought a Nokia E51 & installed tom tom Nav 6, but when I start the programme all I get is the spinning globe and the programme does not load.
Does anybody know how to fix this? Or do I need to install another version etc.
Any advice would be very helpful. Thanks
Im using the latest firmware on the phone & tom tom v6.01 (7640)
wayne4332 wrote:Hi all, I recently bought a Nokia E51 & installed tom tom Nav 6, but when I start the programme all I get is the spinning globe and the programme does not load.
Also me have this trouble. Solved after copy folder with voices to memory card.
You must have a folder on mmc called tomtom containing dataXX.chk dataXX.vif, where XX is number of language voices and a file data.chk (this is very important)
