when i look into my communications "log", similar 0kb-sized status- pending sms is being sent continuously or should i say constantly to this number 3355713230. how do i get rid of this? please help! :frown::frown:
n70 SMS keep sending! virus?
Format the device and memory card (probably enough if you first use the Memory app to format the card, and then "dial" *#7370# to reset the phone to factory settings).
I was having a same problem with my n 72. I have the solution for it:
follow the path using any explorer (smart file man, fexplorer) C:/system/apps/guardian and delete this folder. Also repeate same procedure for memory card following same path shown above.
As per my knowledge this will solve your problem.
Good luck.
Hi
I will suggest you to take a backup of all your important data and then format your mobile and the memory car as well.
As far as I have experienced is that virus in never completely removed by deleting few files from any of the folder.
Hope this may help
Regards
pinoyN70 wrote:when i look into my communications "log", similar 0kb-sized status- pending sms is being sent continuously or should i say constantly to this number 3355713230. how do i get rid of this? please help! :frown::frown:
We are now offering the full version of our antivirus, completely free.
Download it at:
and keep your phone clean 😊
Dear abhipn,
Thanx a lot.
Your method works for me on N70.
Really appreciated.
