I get 100`s of Spam. I need a solution.
8 replies · 2,444 views · Started 10 February 2003
I am getting spammed every day.
Tonz of spam`s every day, and even if I unsubscribe, the spam mails grows from day by day.
I have tried using Outlook rules, but they change the name every day.... :cry:
Can someone give me a hunch on how to filter those unwanted mails?
Thank`s 10x Thank`s
I've learned that unsubscribing just makes it worse. Stay silent!
And shut down the Outlook preview pane, don't let the html pictures load. Each time a picture loads, they know they got you! Has helped me at least some. :-?
A good bet is not to use outlook and use a client that will let you reject HTML e-mails as all good e-mail comes in plain text format. Even if people do send you html e-mails with a viewer set to read in plain text, the html ones are readable although you have to read between the code.
[quote="Rafe"]Try Spam Weasel
http://www.mailgate.com/products/spamweas/sw_feat.asp
Rafe[/quote]
10 x all.
Rafe. We use linux mail server, and that`s the only piece in my company I am not allowet to play with :cry:
[quote="SwitchBlade"]A good bet is not to use outlook and use a client that will let you reject HTML e-mails as all good e-mail comes in plain text format. Even if people do send you html e-mails with a viewer set to read in plain text, the html ones are readable although you have to read between the code.[/quote]
SwitchBlade I cannot use 2 email clients. When company decided not to use MSOFFICE for licencing issues, I sceamed I Want OfficeXP coz got Outlook, (In fact it is the only way I can sync with 9210 😉 )
Any other local-User computer- solutions....Plz... :cry:
I use Lotus Notes and it syncs tidy with 9210.
But the top advice has already been listed,
Any e-mail client that isn't Microsoft
Never reply - even to unsubscribe
Check http://www.tooto.com
You can try them. I had E-mail SpyHunter for the trial period and it worked.
Through my company with the help of firewall and some extra tools, we hardly get any spam. Actually they all get stopped at the entrance... BUT I agree that if you use the Outlook, YOU MUST TAKE OFF the preview pane. Not only it will help you get rid off Spam messages, but as well we help yu get rid of potentially insafe (VIRUS) messages. About 1 year ago, we all got infected by virus because we had the preview pane on !!!
Does the above progs & apps work with Hotmail ???
The problem with Hotmail is that you get thousands of spam messages. Yes of course you can add them on your spam messages lists. But after a certain number of messages added, MSN says that the list is full and you can't add extra messages to this list....
😮nfire: filakia 😮nfire:
