MkII 7650 data cable
4 replies · 2,104 views · Started 10 February 2003
I have just bought a MkII 7650 serial cable which I can't fit on my phone! I am assured it is the right cable but guess it must have some secret panel to enable connection! Can anyone help?
The place to plug the cable in is directly under the camera lens. You really have to take your phone apart (not completely though) to stick the cable in.
yeah theres a pic in this thread:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6106
showing the connection points.
You can use a 7650 Openeing tool to open the phone without damage or use to thin needle screw drivers or similar to open it with the risk of damage. 😊
