Please Help *** E90 Internet is SLOW
1 replies · 2,748 views · Started 15 August 2008
I need some help. I purchased my E90 about 3 months ago. I currently use ATT internet. It works but slow. DO anyone know why? I also have Opera Mini browser which i am having a problem with websites that have numbers per the keyboard is not recognizing the number.
Can someone tell me where to get free good themes and animation or some application i might want to add.
And Why my Internet is so slow. Also from the hm screen if you hit contacts. It takes a good 3 seconds before it comes up. Why ?????????😡😡😡
Pizero does lovely themes and a lot are free
Re internet speed, whats it like using wifi? is it just that you are in a poor signal area and it can't use a fast connection? I believe in teh USA you have slower connections than here in Europe.
check how many apps you rae currently running by holding teh menu key down for a couple of seconds, move to any you don't need and press teh 'c' key to exit them. You will probably find you have loads of stuff running in teh background.
Its also worth checking yu have teh latest firmware installed. Nokia do a software updater tool, download it and run it to make sure you are up to date.
Re Apps, there are lots of freeware tools, it depends on what you want the phone to do? I have all sorts from Sat Nav, games, wifi tools, Putty, google maps, spanish translation stuff etc.
