Nokia Internet Radio issues
1 replies · 3,415 views · Started 17 August 2008
I have used this program on my N95 8GB with no issues at all. I installed on my new E71-2 and it does everything well except playback the sound. Instead I get a message that states: "Failed Radio Playback". I can see the title of the song that is playing but thats all. No sound (just the error)
I checked my settings and it doesn't matter what i select for my access point. Works fine on other devices just not on E71. Anyone else having issues? if not what Rev. are you using. I'm using the program called-InternetRadio_31_n95. Maybe this is my problem? Are their any other versions?:frown:
Update:
Found some answers on the Nokia Forum. Appears that not all versions will work with E71. Many people report same issue as I. Nokia does not make a version specifically for the E71. I ended up installing the version for N82 as advised. I got same error but if I kept trying I could actually get some stations to come thru. weird...
