I no this has probably been asked several times before but what is the best case for the n95 8gb? I really need something thats going to protect the phone from knocks etc as i work in the building industry?
I have a NOKIA CP-235 which i thought was great until i took it off and realised that it damaged the edges of my phone where it clips on at the sides. 😡
Ive still had no luck in finding a decent case that completely covers my phone aswell as protecting it without making it too bulky to put in my pocket, i had to take the whole phone apart earlier to remove sand stuck in the slider so im desperate?
I have the Nokia CP-69 as seen here:
http://shop.nokia.co.uk/nokia-uk/product.aspx?sku=3501394&culture=en-GB
It's great. It opens from the side so you can use it horizontally and it has a button snap closure on the top so you can use it vertically.
Hi Starbubble
I use the Berghaus E-Case Small
http://www.berghaus.com/ProductDetails.aspx?ProductID=1142&Gear=2
It fits the the N95 really well, clips very securely to your belt, it stops the corners being knocked off and has a waterproof cover.
Cheers David
I've got a horizontal belt clip type on eBay. I'm not sure about the N95 8GB (I have an N95-1), but I'd stay away from any with magnetic closing flaps/buttons. The magnets mess with the screen orientation.
You could try this one.
It also clips onto the phone but it's very precisely designed.
I've used mine for 8 months now and there are no signs of any damage at all where the clips attach.
Wombler
Wombler wrote:You could try this one.It also clips onto the phone but it's very precisely designed.
Wombler
Hi mate have tried this one already and the case needs to completely cover the phone to stop dirt/sand/dust etc geting into the phone.
If you look for more style, try this bags from fitbag. This custom-tailored bags are made in Germany.
