im usin xp, n my ir used to work perfectly, until after i formatted n backed my phone up... not my computer doesnt detect my phone anymore! anyone can help?
help! ir problem!
I hope you backed up and THEN formatted.. 😊
Seriously, however, formatting your phone should affect your IR connection.
When you turn your 7650's IR on, does the little balloon pop up saying "Another computer is nearby" (or something to that effect) ?
If it doesn't, there may be a setting that has changed on the computer's side.
If it does, but mRouter (or PC Suite) doesn't recognise your phone, then it's just a matter of adding the phone to the PC Suite.
Good luck..
