Hi Guys,
I have an O2 6220 Classic and want to unlock it so i can use a Vodafone sim. (Is it already unlocked, i don't have a Voda sim to test with at the moment)
I would also like to flash the generic nokia software.
Can this be done in the same way as the N95 using B-Phreaks software and changing the ID.
If so what ID do i need to set it to Europe?
Many thanks.
as far as im aware all o2 phones (except the iphone of course) are unlocked already.
as for your other question, yes you should be able to get the standard firmware by the same method as the n-series (nemesis etc), according to this website (http://thenokiablog.com/2008/08/12/nokia-6220-classic-firmware-upgrade-to-323/) a product code is 0556386
Thanks very much for the info.
