Damn Nokia Software
6 replies · 2,347 views · Started 10 February 2003
Does anyone else find that damn Mrouter and other junk that PCsuite installs damn annoying?
It is messing with the other things i connect to my machine though IR and trying to run other IR Enabled apps when its on is a pain.
Does anyone actually like this or is it hated by everyone else?
Eck
Yes it is very annoying, messes up my IR devices too, I have to disable and re-enable IR in mrouter for other devices to work.
As if PCSuite was not bad enough itself!!!
I feel that we will all just have to put up with it as Nokia are not going to make any dramatic changes due to the life of the average phone. Soon the 7650 will be a thing of the past and we will all be using a new phone with new software (and probably complaning about that too).
Hope your problems do not cause you too much stress
Bob
you are absolutely correcr IR thingy is so damn irritating....y cant they simply have a software that runs at the back & you can add/remove things via the Windows Explorer. Thats it... im sure that would have been easier for them.
By the way i prefer using Oxygen Phone Manager...NOW, thats a good peice of software.Thats got everything.
Anyways we have no choice but to live with it for now. :x
Cheers..
HyPeR
thats a good question...to tell you the truth, i have not tried my 7650 with oxygen manager...thats wierd...i have not...i wonder why? :roll:
but i was just going thru some of their email & i remember they sent me an email with the latest software which does support the 7650...
will let u know soon.
cheers
HyPeR
