Everytime I try to search for a wifi service, I get the following error:
"System error"
The only option I have is to press "OK" and it defaults back to the menu.
I've checked the software and its the latest version for the handset as per Nokia's site - any info to resolve this would be great.
Thanks in advance :icon14:
HAPPYTREE wrote:Everytime I try to search for a wifi service, I get the following error:"System error"
I have seen this on my handset. In my case it was caused by Devicescape that had trouble to start at boot. I had it fixed by restoring the configuration files using the reset code. Try first soft reset code *#7370#, if that doesn't help the hard reset code *#7780#.
If I do either of those reset methods, will I lose things like my SMS/MMS/images etc?
I have no other software installed other than the stuff that was on the handset.
HAPPYTREE wrote:If I do either of those reset methods, will I lose things like my SMS/MMS/images etc?I have no other software installed other than the stuff that was on the handset.
You should not. I lost some configuration (like I had to reenter my WPA key), but not SMS/MMS. Anyway, it's always a good idea to backup first....
Cheers, I'll give it a whirl!
Thanks for your help, all fixed! :icon14:
