N70 ME - Bluetooth Problem...
1 replies · 2,626 views · Started 22 August 2008
I have n70 me.
Whenever i try to send a file via bluetooth to some other mobile ph, it shows up - Sending failed or connection failed (at the starting of sending), but when others send any file to me via bluetooth, the bluetooth works fine.
why is there such a problem?? what should i do ??
HELP......:icon4:
Hi
As far as i think there is no problem with your bluetooth .
As if there would have been any such problem then you would have not been able to receive files as well and also you gallery section is not accessed when there is some problem with bluetooth.
Just take a backup of your files and format your mobile as I have experienced that the best way to all such problems is just format your device .
There may be some other way out but this is the easiest and the most reliable one
speed123 wrote:I have n70 me.
HELP......:icon4:
