when I was on Orange with my N80 whenever I had a voivemail message teh icon would appear.
now I'm on Vodafone on my e90 I can't see any way to get it to do the same? I get a text from voda buit I'd rather just have teh icon come on.
Anyone any idea how to enable it?
I'm with T-Mobile and get the icon.
Are you sure you're not using the network's voicemail rather than the phones?
i'm on voda with my E90 and have both a text and an icon when i have a voicemail, as far as i can remember i set this up by going through the options when calling my voicemail, alternatively i think you can change the settings on-line if you are registered at vodafone.
Cheers, I'll have another dig through teh options, good to know its possible though
