Does anyone know a work around for Telenav/AT&T Navigator on the E71?
I tried to download the E62's application file for the program, but I'm guessing it not compatible, because I'm getting an Expired error.
- Changing the date is not helping me either.
bump. anyone find a way to do this yet? if you go to att.telenav.com/nav from your e71, it allows you to download the att nav for the nokia 6650, but then you get a certificate error at the end of the installation.
with the ATT branded e71x floating around out there, there has got to be a way to get the att nav off of it to use on unbranded e71? right?
I finally figured out how to add addresses and look up businesses on the web and synchronize them to my Navigator's "Favorites". If anyone is interested here is the link: http://my.telenav.com
