Any chance of external aerials for phones anywhere?
I remember all the old phones had them but I cant find an N95 one anywhere. Does it even have a connection for one?
External Antenna
All new phones use an internal arial their is no need for an external one in this day and age. Why would you even want one?
i'm guessing he's referring to the need for an aerial for receiving radio perhaps? I think you're supposed to plug headphones in to act as an aerial. Perhaps past models could use a dedicated one? Could that be what goes into the little socket on my N95-2 between the charges & USB?
christofff wrote:Could that be what goes into the little socket on my N95-2 between the charges & USB?
Isn't that the microphone?
Better reception in places where the internal antenna is not enough is the only reason where it'd be useful, but if you for example live in such a location, then...
ah, that would make sense... I'd not looked for the mic no this phone!
N/A wrote:Better reception in places where the internal antenna is not enough is the only reason where it'd be useful, but if you for example live in such a location, then...
Exactly what I meant
srw985 wrote:Exactly what I meant
Change network if the reception is bad might be a hell of a lot easier.
