Anyone using neu voice?
7 replies · 1,870 views · Started 10 February 2003
I have had a brief look at a trail of this programme, but haven't seen much posted on it or seen it updated. What do people think?
I found that I haven't got access to my already made contact tags. But the 3 tags I have made work ok, is there a way of setting it up to activate your own event, like start a programme you have installed?
Thanks for any help.
I bought it! Here you are:
1. Most recent version is 1.05.
2. It does not support your phone's voice tags.
3. You cannot activate a third-part app.
and a bonus info:
4. It does not work with HDC-5 hands free, and they said that they won't support it.
5. There was a problem with firmware v.04.39 related with audio playback. They fixed it at NeuVoice v. 1.02.
It's wonderful app, but it takes a lot of memory space and the most dissapointing issue is the HDC-5 missing support...
What's the meaning of an app like this without hands-free support? :-? :x
That is strange the demo I am using seems to support the HDC 5, why remove it? Tha t is version 1.01. I tried to call a voice tag whilst driving and the phone in its case on my hip, there was no way the phone mic could have heard me it must have been the HDC.
Well, officially NeuVoice told me that their app does not support HDC-5 and they will not ever support it. What that means: If you press the HDC-5 button, NeuVoice will not respond, the default phone-built-in voice recognition engine will be activated.
In your case, are you sure that when you pressed the HDC-5 button you activated the NeuVoice app and not the default Nokia voice recognition engine? I suppose that you haven't delete your existing voice-tags from phone and here's the mess... Why not try to speak a command to see what happens? (e.g. "Bluetooth"😉
In my case, when I press the HDC-5 button, it activates the default Nokia engine -not NeuVoice- even with 1.01 or any later version.
I am repeating that: official, NeuVoice said that they don't (and won't) support HDC-5.
I am very curious if this can happen... It will be very nice! 😊
Ah! That would account for it, no I did not press the HDC button, I pressed the one on the phone and spoke through the HDC microphone, it was a command tag I tried and it worked.
May be this is a way for me to use the trail for more testing, using the phone button for the 3 allowed tags and the HDC for my norml contacts. 😃
[quote="liverpool lad"]any more impressions on Neuvoice???
Paul[/quote]
the tags for Work and Home are exchanged i.e. the Work tag dials the Home number and vice versa
