Hiya All,
I have a Bluetooth Dongle in my Work PC for connecting to my N95 8GB, after doing a windows update, it recognised a new bluetooth driver, after installing, I couldn't get PC Suite to work at all, then after hunting around, I found some additional bluetooth drivers from www.VinsVision.com.
This got my commection to PC suite back up and running again, and I assumed all was ok until I came to connect to the internet, it connects ok, but then immediately disconnects straight afterwards. I have the correct Mobile Service Provider etc, the only difference I can find is that now in windows management, I dont have "Standard Modem over Bluetooth Link", but instead I have; "Standard Modem over Bluetooth Link #13" and "Standard Modem over Bluetooth Link #14", although when you try and connect using the "One touch access" it uses "Standard Modem over Bluetooth Link #7" ????
Is this hard coded somewhere, possibly in the registry that I can change to get this up and running again ?????
Help would be VERY much appreciated,
Cheers,
Scott
