Phone case
6 replies · 2,123 views · Started 11 February 2003
I found the oerfect phone case...Where? at a camera shop. The case I found is called Canon Power Shot. It's blue and about the size of...oh well, a pocket camer.
It has a belt loop and a separate compartment with Zpper, Ideal to keep extra Memory cards and headphones. It even has a small whole on the top that can be used for the strap or headphones. I don't know yet how to eork the phone, but when I have a chance I'll post a picture. Meantime, Check Camera Stores.
Hey! Thanks for the tip... Could you post a picture or a URL?
Also, how much did you pay for it, and how usable is it?
For example, is it easy to get to the phone when it rings?
Okay, I got a couple of bad pictures. It is very easy to access the phone from it. It cost me 15 $ US. The phoe seems very snug in it, and again as a belt clip its ideal. If you like to hang the pnone around your neck. (I often do) it's a little bulky, same thing if you plan on keeping it in a pocket. For belt and In bussiness case it's great.
You'll see the case is a little thicker than the supplied, but that's because it stays in shape rather than flatten when nothing's in it. It's a little shorter and rounder and much more protective. The seal reads Canon Power shot, i don't know if it's an original though.
Thanks... Just to make sure, you can clip it to your belt?
Is it an original Canon accessory? If so, does it have a reference number?
If it is not an original Canon accessory, do you know which specific model of Canon camera it was designed for?
