Misc software questions for the E71
0 replies · 3,139 views · Started 30 August 2008
Here are some questions that have popped up for me while using the E71. If you can answer any of them I'll be grateful. Thanks!
-When I add a "todo" entry in the calendar "from a certain date forward", the todo entry shows on the home screen immediately. I want to not show until the date I entered has come. Is this a bug?
-Is there any quick way to switch between full screen view and normal screen view?
-There's a headline called download! where I can download fsecure and some other applications. Are these full versions for free? Is antivirus necessary?
-Is it possible to open a new browser window when clicking a link?
-How can I remove all the default bookmark folders?
-When at the home screen and wanting to browse the internet, is the any way I can just start typing what I want to browse without having to go open my home page first?
-When browsing, is it possible to go back to the previous page with one click? (as I do it now, it takes 3 clicks)
-Can I copy calender events? Or repeat calender events for a number of weeks or months?
-When are "notes" best to use? When are "active notes" best to use? When is "office" best to use?
-Can I set the phone to use a certain wifi if available and 3G otherwise, without the phone having to ask me for access points every time.
-How do I record phone calls?
