CAn someone explain how I install ROtate me? I am confused by the "unsigned" program. I have only downloaded programs that simply installed automatically.
Rotate me
See item 3 here for Symbian Signed instructions:-
http://sjc-123.blogspot.com/2007/09/best-tips-and-tricks-for-nokia-n95.html
Good luck!
Why use Rotate me when you can use the screen rotation setting?
Go to tools - settings - general - personalisation - display and change rotate screen to automatic.
hatchie wrote:Why use Rotate me when you can use the screen rotation setting?Go to tools - settings - general - personalisation - display and change rotate screen to automatic.
Not on an N95-1 (classic) you can't!!!
nor on my N95 8GB...
Version 15.0.015 RM-320
what software version does that then? 1st i've heard of it!
All i get is light sensor, font size, power save, welcome note, light time-out.
christofff wrote:nor on my N95 8GB...
The Nokia N95 8gb has it on firmware version 20.0.016 for unbranded, generic (Euro1), firmware. Also available on Vodafone branded firmware.
Been out for about for 4/5 months. See here:-
http://www.allaboutsymbian.com/forum//forum/thread/71828/&highlight=n95+8gb+v20
hmm, i am lagging behind! Time to reflash i think... Thanks for the info.
[email protected] wrote:The Nokia N95 8gb has it on firmware version 20.0.016 for unbranded, generic (Euro1), firmware. Also available on Vodafone branded firmware.Been out for about for 4/5 months. See here:-
Also on 3 branded handsets V20.0.016
I just looked and my n95 does not have a rotation option. Where can I check to see which version of software I am running and where can I go to flash new version? I thought I had the latest version, obviously I do not. Do I lose all my programs if I update OS?
scottyb159 wrote:I just looked and my n95 does not have a rotation option. Where can I check to see which version of software I am running and where can I go to flash new version? I thought I had the latest version, obviously I do not. Do I lose all my programs if I update OS?
hi there press star hash 0000 hash on main standby screen of phone this will bring your firmware up
go to nokia support for your country via www.nokia.com youll find the update service there its called nokia software updater
please see the sticky threads at the top of the n95 page for more info on firmwares etc
you will loose all settings programs and contacts ie yourphone will be factory fresh apart from memory card or you 8gb storage depending on what phone you have
back up contacts and messages but i wouldnt backup any more the restore them as when you do settings etc it can cause problems just do contacts and messages then build your phone again like you did when you bought it you should have the applications and liscences still on your pc , no?????
I have the most recent version for the US, it just doesnt have a rotate feature. I will try to get rotate me to work as described above.
I tried to follow procedures for an hour and simply cant do it. I try to follow the signed instructions and cant get the application to be seen properly
I recieved errors saying Failure for many reasons. Is there any other way to do this?
visit this link mate
itll show you how to hack your n95 so it will take any app unsigned or signed
you will have to be carefull what you install as the security is turnt off so download from places with good reps and avoid torrents if poss just incase
it dosent void the warranty and i know at least 5-8 people withn95s that ive done it for including myself
all youd have to do is a reformat and the hack would be gone
but i recomend it mate
scotty try not to double post as well
Where did I double post? If I did, it was an accident. I have two posts, one regarding rotate me, and the other about video conversion.
scottyb159 wrote:Where did I double post? If I did, it was an accident. I have two posts, one regarding rotate me, and the other about video conversion.
I count 3 posts on Video Conversion:-
http://www.allaboutsymbian.com/forum//forum/thread/75570/
Sorry, no idea how that happened. I only submitted it one time.
Buxz -- Thank you very much. The hack worked perfectly and rotate me is working.
I can confirm that there is an option to change screen to automatic on my Vodafone N95 8GB version 20.0.016. and it works great.
Only thing is I have to rotate the phone to the left to work first time. If I do it to the right it takes 3 turns to work.
Cheers
Thanks for the useful informations guys😊
