Where/how can i see the amount of traffic i have with gprs ?
And there must be a way to reset this counters ?
Thx.
gprs counters
Check out the "Log" and "Connection Manager" applications on your phone (assuming you have an S60 based Eseries phone as you posted in the Eseries forums).
Thx.
Can you detail the way to find this (eg menu, ..., ...) ?
I use a E61i.
I have an N95 8GB at hand. On it the "Log" application is here: menu > Tools > Log. And in the Log application itself go to "Packet data".
The "Connection Manager" is under menu > Tools > Connectivity (and listed there as "Conn.mgr."😉. Choosing "Active connections" will show the amount of data during the current active connection so far.
