while uploading applications to N95 8GB i have an error coming up saying certificate error contact application supplier but its happening with every app i try?
Any ideas as new to N series.
thanks. chris.
thanks. chris.
windybob wrote:while uploading applications to N95 8GB i have an error coming up saying certificate error contact application supplier but its happening with every app i try?
thanks. chris.
Chris,
Change the date on the N95 back one year and try again. Your aps should then install ok. Once you're done you can put the date back. Worked for me.
ok just tried that but its not working. i'll try downloading the app again and try. thanks.
ok for now had to do this
"Application manager, options, settings, software installation and change that to all" after that they worked!
thanks.
