Nokia N70
1 replies · 1,540 views · Started 03 September 2008
Hi
I am looking to upgrade my aged Nokia 7610 to a less aged Nokia N70. I read a few reviews and I am impressed with this handset. I have a few questions that none of the reviews have answered.
1) How well does the PC Sync work using Nokia PC suite? Can it be setup so that the unit syncs automatically when connected to the PC?
2) How easy is it to find information once entered in either Calendar, Contacts or Notes? Is there is an option (built-in or add-on) to search for information in all PIMS?
3) How about essensial apps? Can any of you recommend any?
Regards
Patrick
I have not used N70, but you may get answers for your queries regarding PC sync and essential apps guides, reading some more reviews and articles. Other features are good, especially for an entry level N-Series phone. 3G calls are entertaining to use. Phone memory for contacts is practically unlimited. Just have to take care of the casing since it's prone to wear and tear. The camera is decent.
