Nokia 9300
3 replies · 2,999 views · Started 03 September 2008
Hi
I am looking to upgrade my aged Nokia 7610 to a less aged Nokia 9300. I read a few reviews and I am impressed with this handset. I have a few questions that none of the reviews have answered.
1) How well does the PC Sync work using Nokia PC suite? Can it be setup so that the unit syncs automatically when connected to the PC?
2) How easy is it to find information once entered in either Calendar, Contacts or Notes? Is there is an option (built-in or add-on) to search for information in all PIMS?
3) How about essensial apps? Can any of you recommend any?
4) Most important for me because of my poor eyesight. Do any of you know of magnification software that will run on this unit?
Regards
Patrick
Didn't you , 106112909, post the same question elsewhere, stating you're considering switching to the N70? Now it is the 9300?
