I have a problem that has just started on my 8gb. I have always been able to login in to forums and user boards with username and password but now i just end up in a loop that says you must log in to view these boards.
I beleive it to be soemthing to do with rejecting cookies, I have tried changing the settings and rebooting and then change the cookies back to accept and rebooting again but to no avail. I have also cleared out my internet cache but its made no difference.
Any ideas?
Try resetting your phone to the factory defaults
how do I do that?
I am on 15.0.015 FW so I might upgrade to 20.0.016 if it makes much diff
Messer wrote:how do I do that?I am on 15.0.015 FW so I might upgrade to 20.0.016 if it makes much diff
To restore to factory settings:-
Menu > Tools > Settings > General > Factory settings
Upgrading firmware to version 20 is only possible on unbranded and Vodafone or 3 branded handsets. You can check if your handset is eligible for an update here:-
http://www.nokia.co.uk/A4777089
If you do update and then restore the handsets contents from Nokia PC Suite's Backup/Restore prog. then DO NOT restore the Settings as these have been shown countless times to cause all sorts of problems.
Good luck!
Restoring to factory doesnt do anything for my problem...
