I like the E71 calender, but there are some extra functions I'd like to have. So I wonder if there are any modifications to the calender, or plug-ins, or alternative calender applications, that can be downloaded. If you know of something like that, it would be great if you could put up a link.
E71 calender - mods, addons?
I used to use Papyrus on my Windows device, and there's a Symbian version available.
I think the Symbian version isn't as far advanced, but might give you what you need. Personally I like the built-in calendar, so I've not tried it.
I just read a review on allaboutsymbian about it (http://www.allaboutsymbian.com/reviews/item/Papyrus.php). I might get it. Thanks for tip.
A side question. Is it possible to change the target of the four quick buttons on the E71. Like if I wanted the calender button to point to papyrus.
Yep:
Tools, Settings, General, Personalisation, One-touch keys
You can specify a short-press and a long press action
