Settings not saved phone connection link
0 replies · 1,781 views · Started 11 February 2003
There is a small app used for the phone connection which sits in the system tray: the phone connection link (two arrows <=/=>😉.
In the properties you can set which connection it should use (cable, IR, bluetooth). I use IR on my laptop, but the PCL doesn't save the setting. After reboot I have to set it to IR again.
Any suggestions?
