how do i know when my maps need updating?
3 replies · 2,160 views · Started 08 September 2008
on my n95 8gb? without waiting until it tries to take me down a road that no longer exists.
Is there any way of plugging it in online and it teling me?
I have whole of western europe on my phone.
Liam
This is one of the things I requested in my list of changes to make to Nokia Maps (and maploader).
It detects which version of the maps you have, and automatically prompts for an update when you use maploader.
Of course, they might not listen to me. 🙄
At this current time, you have no way of knowing. Silly really, considering thats one of the main strengths of nokia Maps.
bartmanekul wrote:This is one of the things I requested in my list of changes to make to Nokia Maps (and maploader).
i noticed it says
says at bottom of nokia map loader 2.0.2:
current drive: E: at Nokia N95 8GB at (map VERSION 0.0.12h)is that anything to go on?
map version listed but there is nothing to compare it against online..
I have whole of europe so I would like to know if say Spains needs updating, or UK or Cyprus etc
reply from nokia see if you agree
"Dear Liam, Thank you for contacting Nokia Care. With regard to your email, to update your map data in Maps 2.0, go to Options > Tools > Settings > Map > Options > Check for map Updates (this is only possible if you have allowed the mobile internet connection). If there is a new release of map data, the application will prompt you to delete the preloaded map data. When Maps uses a mobile internet connection, large amounts of data may be downloaded to your mobile device, resulting in costs arising from the download. You can also use Nokia Map Loader to update your maps. Please refer below to do so: 1) Log on to www.nokia.com/maps on your computer. On that page click on the "Downloads" link. 2) Download, save and install MapLoader 3) Once installed, plug in cable to PC then phone 4) Select "Mass Storage" mode when prompted on your mobile phone 5) Select country on MapLoader that you wish to install to phone Note: Maps are all installed to you phones' memory card. "
