route 66 TMC update issue?
9 replies · 4,662 views · Started 08 September 2008
Hi all,
i have an N95 with Route 66 isntalled, it works great, but I have just moved from Spain to the UK and the TMC does not appear to be working anymore. It says updating, makes a 3G connections and then says there is no info (which sometimes I do not beleive!!) It worked fine in Spain...
I have the correct settings for the access point defined (im with O2 and have selected O2 mobile Web which is correct) and as I said, it correctly establishes a connection but does not receive any info....
Any ideas? Can anyone explain further how TMC updates work?
Thanks in advance
I have version 7.3.468
I didn't realise I had to pay for TMC... WHo gets paid? And I cant understand why it worked fine in Spain but doesnt work here in the UK?
Thanks for your help and info.
Edit : Just been to Route 66 website and there is no mention of paying for the service, just the additional data charge from the operator... WHere does it go to get the info? And can I verify that there is any data to be downloaded? Is there such a thing as a TMC 'server'?
Gavin Watson wrote:i have an N95 with Route 66 isntalled, it works great, but I have just moved from Spain to the UK and the TMC does not appear to be working anymore. It says updating, makes a 3G connections and then says there is no info (which sometimes I do not beleive!!) It worked fine in Spain...
Presumably you only had paid/subscribed for Spanish TMC?
Gavin Watson wrote:Hi, I haven't paid for TMC at all, ever...
So if I would like to use TMC, who gets paid for it?
Maybe you got 1yr free Spanish TMC when you purchased the Spanish Maps?
Presumably after entering UK Access point settings on your phone, you changed the default GPRS connection within Route66 Settings menus?
I certainly dont remember any mention of free TMC, I didn't even know you had to pay for it...
Anyway...
Yes, I did change the access point to O2 Mobile Web and now it connects to the server, says 'updating' but nothing happens, the data connection terminates, but it says 'No TMC information available' which I find hard to beleive is always the case.
Anyway, who/what do I have to pay/subscribe to?
Gavin Watson wrote:I certainly dont remember any mention of free TMC, I didn't even know you had to pay for it...
Anyway...
I am using Route66 V8/2008, and the purchase service options are in Extras menu.
hi, thanks for your answers, unfortunately i dont have an 'extras' option in my menu's...
Anyone else any ideas?
thanks
