internet connectivity problem using ivt bluesoleil
1 replies · 5,303 views · Started 10 September 2008
Hi. how do i connect my nokia e65 phone to the internet using bluesoleil 1.6.1.4.
ive been trying to use the "Connect to the internet" in PC suite, but doesnt give me the option to select from the list. i Can connect to pc suite v. 6.85 using bluetooth but everytime i tried to connect to the internet i does not work. im able to connect to the internet via pc suite using a cable but i would like to use bluetooth. please help me with this. thanks in advance.
Hi, I did connect to internet thru BT on my E61i. I downloaded the BT modem driver from Nokia site; then installed the driver. From the internet connect prg on pc suite selected the BT modem instead of USB modem. All that is needed after this is to click connect. Hope this helps. Good luck. Sayef
