WLAN & VoIP problems on V30
4 replies · 3,089 views · Started 10 September 2008
I have both the N95-1 and N95 8GB, unbranded, and have upgraded the firmware on both to V30.0.015 and V30.0.018.
My problem is that since the upgrade I have been unable to use the Public Access WiFi where I live (Linksys). I cannot connect to the web on either phone (Web: No gateway reply 25022) or use either TruPhone or Gizmo VoIP (Unable to connect the Connection network).
The Linksys access point is defined on both phones and Linksys shows up on WLAN scan and the Wlan symbol appears at the top of the screen.
I can connect to the web using Vodafone WAP but cannot connect either TruPhone or Gizmo the same way.
I have changed the WLAN settings as follows:-
Menu > Tools > Settings > Connection > Wireless Lan > Options > Advanced settings > Yes > and disabled Automatic configuration and Power saving and my TX power level is 100 mW.
Up until the updates I had no problem at all connecting via WLAN to either VoIP services or the web using these settings.
Any suggestions or is anyone else experiencing this?
I had a similar problem but it was an issue with the firmware of the router. When that was downgraded everything started working again fine.
Not sure if it could be comparable that the linksys is not playing with the latest fw of the phones?
Just a quick update... reinstalled TruPhone and it is now working fine on the 8GB as is Gizmo on the N95-1.
