Nokia Conversation Doesn't Work Anymore!
4 replies · 2,971 views · Started 11 September 2008
Title says it all. It no longer works.
Either it doesn't record my parts of the conversation or just plan old doesnt list anything.
Anybodyy else found this?
I've got the Internet Support Services pack installed, and the FP1 version installed. Wondering if it's v30 related...
Anybody else using it?
D
Havent re-installed it since the upgrade... was getting a bit fed up with messages being delayed or deferred.
I had the same problem when upgrading to v30. By accident I installed Settings from Backup and then encountered your problems. Bit the bullet and did a hard reset and then re-installed everything piecemeal. Conversation works fine now. Its still my favourite Nokia prog. Just needs a bit more developement though.
[email protected] wrote:Just needs a bit more developement though.
Which by all accounts they won't be doing 😞
That's a pain though. I formatted memory card and did a hard reset (after messaging was crappily slow) just the other day and it still doesn't work...
I wonder if there's some directory where it stores some config that could be purged...
*sigh*
davecozens wrote:Which by all accounts they won't be doing 😞
*sigh*
I trust that you have installed both the Internet Services Support Package and then the correct edition of Conversation for your phone and that they were both installed on the phones memory. See here for link:-
http://www.nokia.com/betalabs/conversation
