hi all
i have the 8gb. When i select OFFLINE profile, if an alarm goes off, or a calendar appointment reminder goes off (i use exchange for mail to sync my calendar from exchange).. the alarm sounds.
I need the Offline profile to be silent!!! surely there's a way to achieve this, but for the life of me I can't figure out how.
can someone please shed some light? I work in theatre and use offline mode when the show starts as silent is no good (if someone sends me a txt i'll get the interference noise through my amplifiers!!) - but i can't have an appointment reminder alarm going off mid show!!! i prefer not to turn the phone off (which is what i've had to do as a workaround), because i don't use a watch and need it for the time.
please help!
thanks
Dave
Tried changing the profile settings for the Offline profile?
Ringing tone > Off
Message alert tone > Off
Keypad tones > Off
Warning tones > Off
N/A wrote:Tried changing the profile settings for the Offline profile?Ringing tone > Off
Keypad tones > Off
Warning tones > Off
thanks, but yes i have. they are all off
floyd99 wrote:thanks, but yes i have. they are all off
I seem to remember someone else in a similar situation and I think we discovered that the fone assumes that if you set an alarm, you need to know about it, thus ignores any other settings and just tells you.
I guess your other choice is to change the alarm style for Offline.
kontraband wrote:I seem to remember someone else in a similar situation and I think we discovered that the fone assumes that if you set an alarm, you need to know about it, thus ignores any other settings and just tells you.I guess your other choice is to change the alarm style for Offline.
Where would that be set ? in the offline profile there is no alarm tone.
