I can not send mms or sms mgs i have checked mgs center and that is correct is there a way 2 return the 7650 2 its original settings not just restore defaults please help my e mail is [email protected] please help
Help
Enter *#7370#... this will delete any settings you have in your phone. If you then phone your operator, they will be able to give you the settings to enter.
*#7370# will reset your phone to the original state of when it was purchased. In other words, all images and programs you have installed on the phone will be deleted.
Make sure you have full battery (and plug in the charger cable just in case)
