Hello all - I have an N95 8g.....love it so far!Would appreciate some help please!
I created a folder in Applications called My Apps, and moved certain apps into it (obviously!) backed up my phone, had phone exchanged(it kept freezing)restored the backup and now I want to delete this folder, but phone wont let me! I removed the apps from the folder first......
Deleting a folder
Put your memory card in a pc and do it that way.
Also, if your phone kept freezing, the worst thing u can do is back it up on card and reload it onto new phone. Cos quite often (in case of sony ericssons its always) you are just transfering over whatever was causing u the problem in the first place!
tigerfox wrote:Put your memory card in a pc and do it that way.Also, if your phone kept freezing, the worst thing u can do is back it up on card and reload it onto new phone. Cos quite often (in case of sony ericssons its always) you are just transfering over whatever was causing u the problem in the first place!
No card in the 8gb!!!
However, as mentioned, you can link your phone to the computer via USB and delete the folder that way.
Thanks for the replies - still wont delete! Its annoying the hell out of me....
dragona wrote:Thanks for the replies - still wont delete! Its annoying the hell out of me....
Try installing Y browser and see if that will delete your pesky file:-
Have you tried connecting to a PC and when looking at the folder via Explorer you right click and check the properties of the folder? It may tell you something.
