Cant unlock keypad
6 replies · 3,275 views · Started 12 September 2008
Hi Guy�s,
I have a little problem that seems simple but its driving me mad. I have just got a new E71 and the first time I turned it auto key locked it self. When I follow the manual to unlocking the keypad it wont work. I have pulled the battery out and replaced it and it is still locked. If someone can help me that would be much appreciated.
I was thinking of reinstalling the software and hoping that might fix it. The buttons do seem to work, it�s driving me nuts�!
but when you turn it on it's not locked... at least it should not be...
try to leave the battery out of the phone for a few minutes....
go to tools, definitions, general, security, phone and sim card, and disable the key lock
I cant even do that. As soon as the phone boots up it locks the keypad that fast I cant even press a button. Its dumb.
